Prop selection
dahman01
I have a 13.75x21 now on a 89 maxum with a 5.7 and run 4200 RPM at wot but I do not have a very good hole shot and thought about going with more pich but 21 is a big pitch will it hurt to go more or stay with this prop??? :confused:
dahman01
Re: Prop selection
this was the original prop on the boat when i got it bout original on the boat not sure? what pitch would you get to have a good hole shot i am not to worried about top end speed as much.
tommays
Re: Prop selection
its really trial and error the boat should reach its nameplate WOT with its normal load to give the best performance<br /><br />i am asking how well the motor runs because if its in good shape and tuned well it should have no problem with 13.75 x 21 the next size down is a 14*19 and that seams small for a 5.7 motor<br /><br />how big is the boat<br /><br />tommays
Wart T
Re: Prop selection
How big is the boat and what is the typical load in it and what is the boat used for?
dahman01
Re: Prop selection
sorry guys just getting back busy week the motor runs good it may need a tune up the plugs are a little bit black. The boat is 20' and with 4 people it just dont want to get up to plain it is used to ski and tube.
tommays
Re: Prop selection
well you can try a 14*19 its the next size smaller and will give a better hole shot<br /><br />if you have not done a tune up in a long time i would try that first 5.7 is plenty of motor for a 20 foot boat i have a 1995 maxium 20 ft with a 3.0 and it will push the boat just fine i think it would jump out of the water with a 5.7<br /><br />tommays
