Re: Prop Selection Sea Ray 185 Sport
I have the same boat, 2004 vintage, the best thing I have done is to put Smart Tabs on mine. I did change the prop after the tabs and got a 14X23 Turning Point prop, I had to Exchange it for a 14X21 to get top speed and wot back. The TP prop is a very aggressive prop and the 4.3L 190 Alpha does not have quite enough power to turn the 23 pitch. My boat with the stock prop will turn just over 5000 rpm, now with the 21P TP prop I am back to the same wot. That is the extent of my prop experience. If you get a 21P prop of the same design as the stock prop you are going to raise the rpm 200 to 400 rpm so you will have to watch the wot so you don't lose and engine from over reving.
When I put the Smart Tabs on my boat I then started using about half throttle to get on plane, got rid of most of the bow rise as in never lose sight of the water in front, run faster, use less gas, low speed wander is gone, handles rough water much better. If you go up in the other forums to
Boat Topics and Questions (not engine topics) and
Prop Questions and Topics
Do a search on Smart Tabs and you will find a lot of information on them.
The site for Smart Tabs Manufacturer is
http://www.nauticusinc.com/ and the phone number is 800-233-0194, You will find the owner posting here and he "John" may even be the one to answer the phone, he posts under jdeargro. I have no interest in Smart Tabs other than being a satisfied owner. You would need the ST1290-60 set and mount the tab bracket in the rear set of holes for a better install. Hope this is of some help.
You should also post this up in the Prop Questions forum.
