Hi Guys
I have a 40 HP evinrude, 1989 model
It has a 12 1/4 x 15 prop on it currently.
The motor is in reasonable condition for a 20 year old motor, runs well and seems to have plenty of power
it fitted to a 4.3 m savage runabout with marine ply floor and a full bimini
Two up it also carries abot 200k of fat people.
The problem I have is that it will only get to 4500 rpm flat out.
If I tilt the motor while underway until the prop starts to break the surface it will rev over 6000, so I know it can get the revs up even if it cant while the prop is submerged.
I have heard that running a motor with a prop that does not allow the motor to reach the recommended wot rev range is not good for it, is this true?
It get to about 28 knotts flat out and will sit there all day.
It takes off pretty good out of the hole and gets on the plane at about 3500 rpm (abour 15 knotts)
The recommended OEM prop is 11 3/4 x 17
I have 12 1/4 x 15
I also have some cavitation issues while cornering and have checked the cavitation plate to the keel, its about 1 - 1 1/4 ' below the keel, which is the recommended depth.
Would a smaller dia prop help me?
I was thinking 11 1/2 x 17 or 11 1/2 x 15 to get some revs up and take some load off the engine.
Also being a smaller dia it may help mitigate the cavitation as it would sit even lower in the water.
Has anyone experienced, tried or seen this solution??
Any help/ suggestions would be appreciated.
I have 12 1/4 x 15
