itsneverfinished
- May 12, 2009
- 55
i damaged my prop this weekend, and am trying to replace it. the boat is a 77 sea ray 240 sdb. the outdrive is a 255 trs mercruiser, the prop is stamped 1940t 19.
It measures about 18.25d x19p, and i can find that size propeller, but they all say they fir bravo II, alpha I etc. my outdrive doesn't seem to jive up with my prop.
so, my question is: are the mercruiser outdrives all the same at the hub? do i have an alpha or bravo drive? i dont want to make my costly mistake worse by buying an expensive paperweight.
i can take pics if need be.
thanks,
brandon
thanks,
brandon
