prop removal
fakeplay
Banned
I have a 1975 johnson 2 hp (r 2 75 d ) and am trying to get the prop off. Do I have to drain the oil and disassemble everything ? Right now I'm looking at a cotter pin though the prop. Is this what holds the prop on ? I tried taking out the cotter pin and lightly tapping around the prop. I want to remove the prop so I can run the motor in a bucket of water so I can adjust the slow speed , high speed needle valves. Thanks for any info in advance.
p.s. I do have a repair manual but it doesn't address how to remove the prop on this particular model.
bowman316
fakeplay
Banned
Re: prop removal
Thanks for the info, but I take the cotter pin out and I do not see a nut, It's a 1975 2hp johnson. could you please elaborate more on where to look ? thanks.
Re: prop removal
Ayuh,... Got a Picture,..??
bowman316
Re: prop removal
There has to be a nut, what is the pin running thru?
just a shaft?
How does the pin hold on the prop?
The set up on my engine is, there is basically a bolt running thru the middle of the prop, and the prop slides on, and there is a treaded bolt sticking out, anf you put a plate on the bolt, like a washer, then screw a nut on the bolt, then put a cotter pin in to prevent the bolt from spining.
But a 2 HP may be different.
I have heard of props getting stuck, from not being removed.
Randybeall
Re: prop removal
I am sorry that I can't help you with prop removal. The reason for my post is to suggest that to make the mixture adjustments you are wanting you need to have the prop on and in the water. A bucket won't do. The prop loads the engine and being in the water makes a difference in exhaust back pressure. Mixture adjustments are affected by both of these conditions. A shop manual should have the correct information on removing the prop, and correct procedure for mixture adjustments. You could damage the engine doing it otherwise.
Silvertip
Re: prop removal
Agreed. You cannot possibly do these adjustments correctly running without a prop and in a bucket.
