Just starting to change the impellor on a '67 Merc 95hp. In reading the manual, one of the first things they say to do after draining the oil, is to remove the prop. I'm not sure if this is a reverse thread and that mother is tight either way. is removing the prop a must or does it just make handeling the lower unit easier once it is off the motor??
