Could some help clear up a few things for me???<br />I have 2001 merc 150 XR6, I have two props one is a quick silver Alum 14.25X21 WOT 5600+@65ish mph(would probably go over max RPM) and a michigan wheel 13.75X21 5000rpm@57mph maxed out. I'm not concern with speed I'm concern with max RPM.<br />Why do I get lower RPM with the smaller Prop?? It seems more logical to me that the reverse would be true - smaller diameter higher RPM?? Could it be because the merc prop is flexing alot and the michigan prop is just a better prop??<br /><br />BTW, I tried a michigan wheel 13.50X23 and had a really hard time getting up on plane.<br /><br />I'm trying to prop it for all around use, and I thing I have done that with the 13.75X21. I'm just the curious to this pheonomina(sp?)<br /><br />Thanks<br />Shawn
