Re: prop questions
In theory, 17pitch moves you 17 inches each time the prop turns. That should be your slowest forward motion at idle. Also, try adjusting your trim -- all the way in will push your bow down, but some boats move slower at idle if trimmed out---pushing the stern down (prop is less efficient at that angle). Might also be harder to steer. Experiment! Also, is you idle set too high?
