Prop questions for 2015 merc 40 elhpt
Sea Rider
Welcome to Iboats,
Some props may experiment that situation but will work OK, need to torque the shaft's nut to factory specs with wrench...
Happy Boating
Ayuh,..... Have you got the right torque hub on it,..??
The prop should be tight on the shaft,.....
huntmtelk
Thanks for the reply guys , I'm not seeing anything referencing the need fr torque wrenches when I watch a you tube on it , Am I missing something ?
Sea Rider
It has never occurred to me to rotate an OEM propeller on its axis before being adjusted with its final assembly pieces, don't know if should have a slight side movement or not while sitting fully in ? The Owners Manual should mention at which NM torque value should the prop nut be adjusted to...
Happy Boating
