Prop question
Jrdeinin
i have a 1999 90 horse Evinrude Ficht that I am putting on a 18ft Mirro Craft flat boat
Wondering what diameter and pitch prop to start with. Prefer Stainless steal.
Any thoughts?
Ayuh,..... Welcome Aboard,...... Is there a prop on it now,..?? If so, try it, 'n see where the rpms are,.....
Sea Rider
Yep, if there's none on the prop shaft try a Evinrude Prop Selector as to dial a starter prop which needs to be wot water tested to check if the motor revs at least around middle of its wot rpm range as loaded....
Happy Boating
Faztbullet
Which lower unit does it have? Does it have a stock or batwing?(see pic)
