Re: Prop Question?
My buddy put a shop tach on my motor and my tach is reading correctly. I was looking on the pontoon forum about a similar situation. "20' Starcraft with a 91' 48hp spl Evinrude, 11 3/4 x 17 prop, WOT 5400-5500 rpm @ 17.5 - 18 mph". Mine is running a little faster top end but his numbers are very close to mine. From what I understand 17 pitch is too much for a pontoon boat running a 40-50 hp. So does this mean I am getting "slippage" as Steelspike suggested? Yes Steelspike the 3,500 rpm is cruising rpm. 5,500 is WOT. Nothing is mismarked or changed out. My motor is one owner '86 40hp Evinrude with 11 3/4 x 17 OMC supplied factory prop that has never been taken off the motor since new. If it is excessive slippage what do you do to correct it? Is it a motor mounting height or prop issue? Or, it's been working like this for 25 years leave it alone?
