Ok I think I need alittle more prop. I looked and I couldnt find a number on mine but here is whats going on. The manual for my motor a 1984 90 hp yamaha 2 stroke says that the rpm range is between 1k and 5200. When I am running full out my motor will turn 6100 on the rpm gauge with no real increase in speed after 5k. Also when I holeshot as the nose is coming down the motor overrevs and for a brief second its almost like it stops pulling. I have a 16.5 ft glastron ssv-167 its a 1981 vhull. Boat and motor with a tank of gas is about 1500 lbs. Do you guys think I need more prop??
