Re: Prop question for DHadley
Hi DH, I don't want to invade this guy's thread, but I have a prop question for you.<br /><br />I have a 40hp Mercury 1977 402(I know its the wrong engine type for the forum, but you sure helped me fix my buddy's Evinrude carbs! Thanks again!). My 40hp is on a VERY heavy little fishing boat... lots of plywood, carpet and my fat butt.<br /><br />It has a factory 13p x 10.75" 3 blade prop (part 48-56236A1 13R) and only runs 19 mph at WOT at 4200 RPM and drops to 3900 RPM with my wife and daughter added.<br /><br />A month ago I thought I had researched this enough and bought a 4 blade Michigan Vortex 10p x 12 from iboats.com Well I dropped 100 RPM, just the opposite of what I thought would happen. I thought 13p to 10p = 600 RPM increase? But 4 blades... design? I dunno!<br /><br />I assume I need to go with the lowest pitch available... it's probably too much weight for the motor, but I am thinking the closer I can get the engine to the 5000-5500 rpm range it will be stronger, more efficient, etc.<br /><br />I see the Hustler 8p x 12.5 is just $70 on sale.<br /><br />Thanks in advance!
