Don Weaver
- May 27, 2003
- 4
Hello, I'm new to this board. I have a problem with the prop set up on my new boat. It's a Alumacraft 20ft tunnel hull with a F115 Four stroke Yamaha on a 10" power Jack plate and a 17 pitch prop. My problem is I think a need a higher pitch prop,right now when I'm a the lowest setting on the jack plate and trimed in all the way at 3/4 troddle I'm pushing 5600 rpms and running 43 mph by my GPS. The book states they WOT is between 5000 and 6000 rpm. At this point I'm not sure what my WOT rpm's are I don't want to push it much and cause problem with my motor. It only has 15 hrs. on it. I'm thinking I need to step up to a 19 or 20 pitch. To get the rpms down. I really don't care much about top in speed 43 is fine. But think I need to get the rpms down to at least 5600 to 5800 at WOT. The weigh of the rig is about 1600 to 1800 loaded. One thing I'm not sure I should try is take it out and go to WOT to see were the top end of the RPMs are. I have a good hole shot the boat stays just about level on take off due to the pontoons on back. It's a new motor and I just want ot make sure I get maney years of service out of it.
