jurgenscraft
- Nov 6, 2004
- 227
I posted a topic some while ago regarding converting from a three blade prop to a four blade proplellor , well what I have found out is as follows :the pitch remains the same but the diamater, has become smaller eg,11 1/2 x 12 becomes 10 1/2 x 12 pitch.( four blade) and a 11 1/2 x 13 becomes 10 1/2 x 13 pitch( four blade) I wonder if any body else has found this to be the case, the motor I am using is a Yamaha 55 with the following specs,wot is 4500 to 5500 ( normaly run at 4000 rpm )gear ratio 13:24 (1.85)<br /> I have not bought the propellors yet so some comments would be appreciated, kind regards William Wright.
