Prop pitch and load questions...
ZmOz
I have a '74 inline 6 mercury 150hp outboard attached to a 16' CV-16. I need a new prop, as a peice of wood took a chunk out of my old one. :rolleyes: The prop I have now is 19 pitch, and I know that's too small because at WOT I can get about 6500 RPMs. If I get a new prop that is 20 or 21 pitch...that should be perfect. What I'm wondering about is pulling skiers and having the boat completely loaded down. At that point, with a 20 or 21 pitch prop, wouldn't WOT be under 5k RPMs? Is that really bad?
Dhadley
Re: Prop pitch and load questions...
Carleson CV-16, what a cool boat!<br /><br />You are correct. Get the 19 redone for pulling the skiiers etc and the 21 will certianly give you more speed. <br /><br />You may be able to swing something even a tad higher depending on what you want to turn for rpm. <br /><br />Youre on the right track! good luck!
ZmOz
If I just wanted to go out for the day...with say, 3 people and a big cooler, would I really need to change the prop for something like that? I would still like to drop everyone off and speed around...without having to change the prop.
