When I turn the key to start the starter engages but can not rotate the engine. Shifter is in neutral position I try to hand turn the prop and it only rotates about 1/4 turn. It will not make a full rotation. It does not rotate in any gear also.
I am new to this outboard motor mechanical stuff; any help would be greatly appreciated. It is a Force 120 1996 model.
Thank you for any help.
bradj
bradj
