prop nut torque
MACH1SCJ
1990 evinrude 48spl ? Model E48ESLESA
Have what I belive to be a stock prop 15 pitch- my question is how tight should the prop nut be, I have not been able to find it in the book. There is the big taper washer at the gear end & what looks like a plastic or fiber washer at the nut end. The nut is a castle nut & held in place be a cotter pin. It was finger loose when I got it & I don't know if I should tighten it up more or not.
Texasmark
Re: prop nut torque
My Merc 90 says 55 ft lbs. If loose it's hard on your gear train every time you shift and can wear out your prop or splines....would take a long time but would get progressively worse.
Mark
jestor68
Re: prop nut torque
That is a minimum of 55 ft lbs for Mercury/Mercruiser.
jestor68
Re: prop nut torque
Some manufacturers (OMC) specify 75 ft lbs; one specifies 85 ft lbs. Mercury only says a "minimum of 55 ft lbs".
If you want to stop at the "minimum" spec, so be it. We torque our Mercury/Mercruiser prop nuts at 65- 70 ft lbs.
We feel that the word minimum (the very least amount allowable) does matter.
Texasmark
Re: prop nut torque
Some manufacturers specify 75 ft lbs; one specifies 85 ft lbs. Mercury only says a "minimum of 55 ft lbs".
I'm quoting what's in MY service manual and I did say what engine it was for. I didn't say that was the rule of thumb for all engines. And again, I quoted from the book, note quotation marks! The word minimum was not used.
jestor68
Re: prop nut torque
The standard manual supplied by Mercury uses the term twice in paragraph 8 of the section on prop installation.
I edited my previous post ; (OMC), so that some useful information was provided for the OP in this thread. :)
MACH1SCJ
Re: prop nut torque
I finally found the spec. It is 120 in. lbs. then tighten to align the castle nut if needed.
