Prop Nut Torque Specification '89 Johnson 50
jsinton
Hi all, could someone please tell me what the proper torque specification is for an '89 Johnson 50 two stroke outboard. Thanks in advance.
jsinton
Re: Prop Nut Torque Specification '89 Johnson 50
Well, turns out I have a '98 Johnson 50 two stroke, two cylinder with a smaller gearcase. It takes a 12 1/4" diameter by 15" pitch prop. The OEM specification for torque on the prop nut is 120 lbs. My prop was slipping bad because I think the mechanic put the thrust washer on backward and the prop nut wound up finger tight. Works good now.
