Prop issues
Berlin boater
I have s 23’ south bay pontoon with a 115 4 cycle mercury turning a 13.75 diameter and 13 pitch prop. The boat runs fine until about 3/4 throttle 18 mph. At this soeed if I try to go full throttle it cavitates. Do I need more pitch? Diameter? Both? Hub is fine and trimming up or down doesn’t help.
alldodge
Welcome,
Cavitation would mean the prop needs to be lower. Can you lower the motor any?
alldodge
If you didn't buy it new, then the leg may have replaced with shorter one. Right now I don't know enough
Faztbullet
