Prop Information
Kadetsr
I still need to know recommended prop size for 1990 Johnson 40 HP. Can anyone help?
Jack Shellac
Re: Prop Information
Suggest you get a Michigan Wheel catalog {may have web page, also]. They have some pretty good guidelines for prop selection. Is also a good prop.
MGuckin
Please keep your posts in the same thread. It is very confusing when we have to search for info.<br />I believe you may have 2 problems.<br />Motor is not mounted at the correct height. Do a search on x factor.<br />Prop is keeping rpms down.<br />Adjust x factor to achieve max rpms and handling first. Rpms s/b about 5500 at wot, assuming motor is running at its optimum mechanical capabilities. <br />If not you can try a different prop.<br />I think you will find that you should be running a 15" not a 17" but your max rpm is still way off even with the different prop pitch.<br />If only running 4400 rpm and tach, is in fact accurate, you are lugging this motor bad.
