Prop Idetification
mrich912
I have a prop from a Volvo Penta AQ225 / 275 OD. I'm trying to identify the size and all I can come up with is a U1767 number. I also see in different locations the numbers 262, 8433. & 22 5. I've searched the net high and low with no luck. I'm thinking this is a 14 x 22 prop as I also had a 14 x 9 for the same boat and this is larger. Any clues, tips, or other places to look?
Thanks
usskydvr
Re: Prop Idetification
Worst case you may need to take it to a prop shop. They can tell you what pitch it is.
nramirez1978
I have a Bayliner Capri with a 225 E 275 OD and my propeller that i had was a 14 x 19.
