Prop Id Help
bese6197
I am trying to figure out what pitch prop I have currently on my boat. The only identification I found on the hub is G883, but could be G833 due to a bad stamp/wear. Prop is aluminum, and it is on a '87 28 HP Evinrude with non-thru hub exhaust. I did a couple quick searches and couldn't come up with anything. I was hoping someone might have seen something similar. Thanks.
ob
Re: Prop Id Help
OMC makes a 388883 p/n aluminum prop that fits that engine and it is a 9 1/4 dia X 11 pitch.
bese6197
Re: Prop Id Help
Thanks - that has to be it. I'll do some more investigating into the OMC props and see if I can find out what is stamped on the hub for them.
