I have a 1962 28hp Johnson RX-10 on the back of my 1957 Cadillac Daytona. It's a bit on the thirsty side but has proved to be nearly buletproof. Yesterday I took it out for a spin on the lake and after several miles at top speed, the engine revs picked up and the boat slowed. I did not feel the clunk that I have always thought jumping out of gear would produce but I don't know what that feels like.<br /><br />The prop is the pin-drive style that came with the motor when I got it. Do these have a rubber hub that can spin? Could the motor have jumped out of gear without a clunk? When I backed off the revs, forward push resumed. Also, when I went to idle and shifted to neutral, reverse and then forward, everything felt fine. <br /><br />I have not changed anything recently except the lower lube (with Mercury Premium rather than the Lubrimatic I normally use). It seemed somewhat thicker but it did say for use with all outboards. Could this be the cause? Have never had cavitation with this boat so I don't think this is it although this is what it felt like.<br /><br />One more thing, I pulled the lower unit a couple of weeks ago just to make sure it wasn't stuck to the leg and when I reconnected the upper and lower shift rods is it possible that I did not do it right? I normally push the lower rod all the way down and shift the handle so that the coupler is also all the way down when I join and secure them. My Clymer is vague on this point...am I doing this wrong? Is this the cause of my current problem?<br /><br />Sorry for the long post but I wanted to include as much information as possible. Thanks for your help, John
