Prop hitting anoide
BillyGoat16
Question about 91 Sea Ray with MerCruiser Alpha 1 Gen 1 5.7L
We were out on the water at cruising speed when we lost forward thrust. Boat came to a dead stop. Put it in neutral then back into drive and would only go about 5 MPH, if I tried to go any faster the RPM's would just rev. Was able to get back to the dock and put the boat on the trailer. Once on the trailer, I could tell that the Prop was back about an inch from the housing of the lower unit. The prop tore up half the anoide. Wondering if anyone has had this happen before and knows what the problem is.
achris
More fish than mountain goat
Hello BillyGoat16, and :welcome: to iboats
You have just experienced a propeller hub failure. Yes, a lot of people have it happen...
Take the prop off and take it to a propeller shop. They will advise you as to the best course. Either a new prop, with the latest hub technology (which you can replace a failed hub yourself :thumb:) or re-bushing of your current prop...
You'll also need a new anode, prop shop should be able to help you with that too.
Chris.....
BillyGoat16
That's what I was thinking too but it looks like the actual prop shaft is sticking out further, so when you put the prop on it will not go all the way into the housing.
greno
Can you put the drive into forward, neutral and reverse?
Is the prop shaft locked in forward and reverse and free spinning in neutral?
greno
I doubt there's anything wrong with your lower. I think your prop hub has shifted inside the prop cavity.
And that would explain why the prop ended up hitting the anode.
if the prop moved, your hub is shot.....period
take prop to prop shop
H20Rat
Also, assuming you have power steering on that, you don't need the anode with the fin. Perfectly fine to just put a flat anode on it since you are going to be replacing it now anyway!
