I have an issue that I?ve been struggling with for some time and hope you guys can help. I trashed a prop that worked pretty well and have struggled to find the right one since. The one that worked was a 15 1/4x15 Black Max. I tried a Quicksilver of the same dia and pitch and it didn?t work, RPMs were way too low. Another I tried was a 16x14 aluminum (don?t recall manufacturer but RMPs were too high and speed too low).
My goal is to increase RMPs without losing (or possibly gaining) speed. My current setup is OK with a light load but with a heavy load it struggles to get on plane (any conditions), and stay on plane when it?s rough. Heavy load for me is 5-6 people plus coolers, etc = 1,000-1,200# +/-. I installed trim tabs and they help a little but not enough. It seems to ride high in the bow with the current setup.
My current prop is a stainless 14?x15 Turbo, I?m not sure of the model.
WOT with an average load is 4200 RPM @ 27 MPH. Heavy load is 3800 RPM @ 24 MPH. I belive my max RPM is 4600-4800 RPM.
Engine is a 260 HP Merc I/O with an Alpha drive.
Boat is a 1984, 26? Stamas Sport Cruiser. Dry weight is 7000# according to Stamas. Loaded and full of gas I assume it?s a little over 8000#.
Like I said, I?ve tried several props so I know it?s not all about diameter and pitch but I?m not sure where to go from here. I?m considering trying another Black Max but they don?t make the exact model any more so who knows how it would work. I also see Solas makes a 14 3/4x15 four blade. And I read on another thread that a Mirage might be a good choice for heavy boats to help with stern lift.
