Gerald Barnes
- Jun 6, 2004
- 32
I have read all the great FAQs and recent prop questions on the forum. Sure helps educate someone who never bought a prop.<br /><br />Here's what I've got:<br />1999 Crestliner 17'8" flat bottom 1030 lbs.<br />1999 J70PLEE<br />Prop 14X19<br />WOT 5600 rpm<br />Cruises about 35 mph<br /><br />Boat performance is adequate for what I want to do. No real complaints since I had carbs rebuilt and decarbed engine.<br /><br />Question: I keep seeing, "Prop for the top", everywhere on the forum. Engine manual "Specifications" gives range of 5000 to 6000 rpm. Next line says "Power 70 hp at 5500 rpm." Is Johnson recommending 5500? Local boat mechanic says 5600 rpm will not hurt the engine. He says just stay with a 14X19 if I am happy with performance. <br /><br />Question: Since I am buying a spare prop anyway, would it be best to go to a 14X17, as recommended in manual, and try to get rpm up to 6000, or should I just get another 14X19 and stay with 5600 rpm? If 2" reduction in pitch is an increase of 400 rpm that should put it at about 6000. What do you recommend?
