Prop difference
JJB
I am looking at I boat ss 17" pitch 3 blades props and I notice apollo ss has a 17" x15 1/2 " and a 17" x 14 1/2 " prop what performance differance between the two sizes ? also between the three ss props turning point , solas or apollo . which is the best prop to get max rpms ?
walleyehed
Re: Prop difference
Probably will get the most RPM from the Solas in SS... the 24-10 composition of the Solas makes a decent prop..it's a tad thinner with the same basic cup.
15-1/2 vs. 14-1/2....the 15-1/2 diameter would be best for high hp heavy boats while the 14-1/2" is a better fit for a lighter, faster boat in this particular blade design.
Not sure what you're after in RPM, but there are ways of achieving higher RPM by changing the set-up if it's an outboard.
JJB
Re: Prop difference
Hey walleyehed , Thanks for the input ! are the lexor prop a better quailty prop then the solas , I know there made by solas . Hey the jack plate worked out great I will post some pictures on my original post tomorrow . It got me another 200 rpms and boat rides so much better then before . JJB
walleyehed
Re: Prop difference
Good to hear the plate is working! how high up have you run it?
The Lexor is a Solas, yes...It's a copy of the Merc Mirage for the most part. I ran a few of the Lexors for Solas and they do a good job over-all. Good load-haulers and have some speed too but I don't think they would be the best choice with a jackplate...I tested the ones I had with a plate, but they don't hold well at the heights a "better" quality, smaller diameter prop will.
I ran them on our wellcraft too, and they did seem to perform quite well submerged.
