Prop Diameter help
Limestone
Hi: I own a 24 foot limestone with a 1988 260hp mercruiser. According the the owners manual, the ideal prop is: 15 3/4 x 16p Aluminum C-48-11322A40.<br /><br />I would like to upgrade to a SS prop but I'm having trouble finding one with the correct diameter (most seem smaller). Questions:<br />1.) What will the effect of a smaller diameter be?<br />2.) What would be the best model of prop. I only care about midrange cruising performance (3400rpm).<br />3.) Is it true that SS props will turn slightly lower # of RPMS then the equivalent Aluminum prop?<br />Thanks.<br />4.) Can I use a "Mirage Plus" on this drive? This prop seems to come in larger diameters.
Re: Prop Diameter help
Hey Lime why wouldn't you talk to the dealer about the prop and get their opinion? I like to do that so I can hold them to it and take it back if they told me it should work out and it doesn't. I'm no expert but I believe I read somewhere that you should drop down on either size or pitch when switching to stainless but there is still no scientific answer or formula. The ideal situation would be for them to let you try it and if you need to adjust, take it back and get another one. I haven't gone to stainless yet but I bought a new aluminum last year and dropped the pitch as a result of some suggestions on improving my hole shot. I checked with the dealer (Overtons) and the guy said as long as I didn't tear it up in the process, he would take it back if it didn't work out.
Boatist
Limestone<br />Only way I know to find right prop is to run wide open and check your rpms. If your rpm range should be 4400 to 4800 rpms and you are in that range then prop should be ok.<br /><br />My boat came with a aluminum prop 13 1/4 by 17 by 3. My RPM ringe is 4200 to 4600. With the aluminum prop boat ran 4600 rpms at a speed of 33 mph. I bent the prop a little but got it fixed but also got a Stainless Steel prop. Stainless Steel prop is 13 3/8 by 17 by 3 but also double cupped, it still turned very close to 4600 rpms with a top speed of 35 mph. Later I got another Stainless Steel prop, this one is 13 by 19 by 3 double cupped. It top RPM is 4200 rpms with a top speed of 38 mph. The 17 pitch has a better hole shot and gets on plane faster but top speed is 3 mph slower and engine turn max rpms. The 19 pitch takes longer to get on plane is 3 mph faster and gets beter fuel mileage, engine still in wot rpm range at 4200 rpms. I use the 19 pitch in ocean where we do not start and stop much and do a lot more cruseing at lower speed and much longer distance. I use the 17 pitch in rivers and lakes where alway starting and stoping for other boats or marineas, also usually much shorter distance.<br /><br />I no expert but small change in diameter I think has very small change in rpms. The bigger size will push a little more water and turn a little slower. A smaller diameter should turn a little faster. Stainless steel props usually cupped and has thinner blades, cupping means prop gets a little better bite. A 1 inch change in pitch will equal 200 rpm change. 2 inches = 400 rpm change. In general terms boat from manufacture should come with best aluminum prop. Large heavy boats normaly have bigger diameter and lower pitch, Smaller lighter boats have smaller diameter and higher pitch.<br /><br />Best prop will be one that at full throttle will be in the recomended rpm range for your boat. Any prop that is in that range should not hurt your motor. A higher pitch will be slower to get up on plane have a little better top speed and get better fuel mileage, but if does reach at least the low end of your rpm range then is lugging the engine and can cause dammage. A lower pitch will jump up on plane quicker have a slower top speed, get lower gas mileage and if it go over the max rpm can also cause damage engine.<br /><br />When picking a prop many dealers will work with you to get the right one and let you exchange if does not meet your rpm range.
bluewater19
The mirage+ is a great prop. I went to mercury marine and clicked on their prop selector program.<br />It spec'd a mirage 15" 21 pitch in my app. Just put in your boat type, length and hp and motor type and it will put you in the ball park. Look on ebay they have alot of mirage props for sale. and you can get a nice one for like 1/3 price of new. If the pitch is wrong. just list it and get another.
