Prop Cup
Flhx
I have a 2005 Mercury 4 stroke bigfoot with a 14X11 prop. I would like more RPMs out of the motor, presently it is 5400. I am going to put on a Black Diamond 14X10 cupped prop. Can anyone tell me what I can expect in RPM change?
Thanks
Robbabob
Re: Prop Cup
Meaning, your RPM is likely to drop by some 300-400.. not the direction you want it to go.
John_S
Re: Prop Cup
I agree with the statements above and have experienced that with Hustler props. I wouldn't consider a stock black max as cupped, unless it has been modified by a prop shop.
Can you provide your current wot rpms, speed (gps prefered), engine hp, gear ratio, and recommeded wot rpm range?
Flhx
Re: Prop Cup
Decided to go with a 14X9 uncupped. Would like to get to 5800 RPM's, right now I am at 5400, with a 14X11.
John_S
Re: Prop Cup
Is this a heavy boat, non-planning (like pontoon), or have allot of deadrise? A 14" dia prop would tend to be on the large size for a typical outboard, which is more like 13".
Flhx
Re: Prop Cup
21 ft pontoon ,60 hp bigfoot, somewhere around 3200 lb.
