Need to know your WOT RPM and current prop pitch to really provide any advice.
You need to adjust your prop so your WOT RPM is in the 4500-5500 RPM range. i would recommend trying ot aim for the higher end of that range.
If you can provide the RPM and currnet pitch we can calculate the proper pitch assuming the slippage remains constant and the speed you report is accurate (GPS vs pitot tube speedo).
