Take a couple more pictures: 1. a side view of the thrust washer mounted on the prop shaft and 2. a view of the other end of the prop,both at that close range. I/we understand your length at the rear problem.
A ruler included in both shots for diameter reference would really help too. I'm thinking that your prop has a detent, like my Laser !! that fits a smaller diameter thrust washer which you may have, like I needed, but your engine has a different length prop shaft and needs a larger diameter washer to contact the raised contact area which will force the prop to sit farther back on the shaft where the splines aren't exposed.
