Re: prop change
What is the operating RPM range of your engine/drive combo?? 5000rpm sounds kind of high. You can go to a 23 pitch prop and that will probably bring your RPMs down a bit and MAYBE give you some more speed. To break 50, you'll probably have to go to a stainless steel prop and they aren't cheap. I'd be more concerned with how quick the boat gets up on plane and how it cruises. If you run at top speed all them time you will have 2 new best friends, the kid at the gas dock and the local engine rebuilder. I've got an 18.5ft'r and don't care so much about top speed, I know I can go 45-50mph but I'm more worried about getting on plane quick and cruising between 24-30mph, go faster and it starts to suck fuel too fast. Solas makes a good prop, I wouldn't worry about them.
