Walleyehed is "The man about props", so he will get ya sorted out. Being an old bass boater myself, you will allways need to bump the trim dowm a bit on turns when trimmed out all the way, and walleyeheds right about the bigger diamiter prop helping your bite and having to maybe br raised at least another hole.Originally posted by Bass Turd:<br /> worried about raising motor because prop has broken loose in turns at high speed!
