catfishredneck
- Feb 23, 2009
- 13
I have a 2001 19cc Promaster Bay Boat that's blowing out around turns. The motor is mounted in the middle hole which doesn't quite put the cavatation plate even with the bottom of the hull. If I drop it down will it help with this issue? I've also heard that cupping the prop will help hold the water better. I'm not sure what that means, could someone explain this to me and do I take it to a prop shop to have it done? I've added a hydrofoil to the motor which helped a little
