Re: Prop advice stainless moving to lower pitch alum and possibly a hydrofoil ad
It is a tradeoff: small prop = good holeshot and skiing, bigger prop = slow holeshot and top speed. <br /><br />I have used clevor type props that rev for holeshot but they are a pain. I found that 4 blades reved less at low rpm and are slower on top end, but that could be boat specific. They are more stable in handling and blow out and useful if your drive(s) are mounted high. I found a Mirage best for all around use. I sharpened the leading edge for 100-200 more rpm and 2 mph, then trimmed up quick just as it came on plane for some cavitation to rev it up. It would grab and plant you in the seat. I used engine mods for more power to pull it but was using a BB chevy mostly(some @6500-6800rpm, 500+ hp). Also ran 305 & 350s. Mercruser normally says rpm range on spark arrestor on carb. The top rpm w/empty boat & trimmed out usualy best if stock, higher if mods. I used SS props only as they were fastest and would hold a good edge. Never pulled skiers at 80mph on Lake Michigan you know, but I think it would have.<br /><br />A hydrofoil might help you get out of the hole better too if your cavitaion plate is out of the water on plane. IMHO, would not use if above not true, otherwise they work good.<br /><br />Extra weight in the boat will just slow the mph/rpm a little per 100lb. You mostly set it up for what you do the most, or top speed if it will still pull a skier or whatever you can get along with(my choice). Over rev is not a good idea with a stock motor. A little normaly does not hurt, but you are just taking life off the motor. Typically stock motors make LESS power above the spec. rpm anyway so it is pointless unless you get a better exhaust, etc, and then improve the valvetrain. That is why it can be slower at a higher rpm with a smaller prop, it is past the powerband. Great for skiing and burning fuel, not top speed. Also can cause valvefloat, a ticking time bomb. Every motor is different though, and some pull at higher rpm, most GM do not if stock. Factory leaves room for error, so stay close to specs and it is ok. I would try/borrow a 19 and see if it will do the job. Best to have the biggest prop that will work, otherwise get two and change out for your use; lots of people do.
