Proline fuel tank
ReelDrag
Can anyone tell me the fuel capacity . 1985 Proline CC 17ft.
jim phillips
Re: Proline fuel tank
call proline in crystal river florida and ask them<br />352-795-4111
ThomWV
There should be an access port or some kind of hatch to give you access to the fule tank sending unit. Pop it and you should see a tag close to the sender that gives the manufacturer's name and address as well as the tank's material, thickness, and volume.
18rabbit
Thom has it right. All gasoline fuel tanks on boats must have a certification label attached that details the pressure testing, capacity, dates, and construction materials of the tank. I would presume it would been accessible…meaning visible from an inspection port.
ReelDrag
I didn't even think of looking for a certification label. Found it near the inlet. 30 gals. Thanks for the info.
