Proline 190 Center Console Owners
eltonh20
I have a 1993 that sits lower in the back than I like when in it is in calm water. I was wondering what the draft is on this boat or how much of the hull sits above water. What I have may be normal but I was wondering. Thanks.
93bronco
Ensign
Re: Proline 190 Center Console Owners
you can email proline at info@prolineboats.com <br />they should be able to answer your ?<br />it shouldnt be too far from the new ones.<br />-<br />i was told the draft as listed for my trophy in 1994 is only an inch different than the new ones.<br />-<br />your motor lbs plays a good part, than you have a battery(s), fuel & what ever.<br />with my 88 j140, i put an additional 60+ lbs back there.
pine island fred
had an 87 16ft. ctr consol. 50 2 stroke. never measured the draft but it sure sat low. found every sand bar out there. water would enter the cockpit thru the drains when anchored. hung an 80 4 stroke ( 384 lbs. ) on it and it drew 30 ins. from water line to the bottom of the skeg. pro line is a good boat but i have seen comments on its draft before. just sold it.
