Hello all,
I'm in the project to swap my 5.7 to 7.4. Boat is 1987 Sea Ray Sundancer 268.
I had cracked my 5.7 block, and prior to this it had some knocking noise, so I'm not very interested to change block and hear the same sound again. During the winter, I've bought 7.4 as non runner, and partially incomplete. Disassembled, found stuck rings on one piston, assembled it back, fired up with basic wiring and left it in my shed.
Now the time is coming to get my boat going again, and I think to put that 7.4 in. There are couple of issues with it, and I hope, that with Your help I'll be in the water briefly.
So lets begin with the list, of issues/missing parts:
1. Alternator. I will use it from my 5.7, pulley is different, but I believe I could get one locally.
2. Circulating pump pulley is touching pump itself. Should be there any washer?
3. There's no raw water pump, but as I will use my alpha outdrive, shouldn't be necessary?
4. No cooling hoses. I will come to that later, as I see what could I use from 5.7
5. Fuel pump I will use electric from my 5.7
6. No wiring, or senders. So I will use from my 5.7. What should be added, or possible problems?
Seems all for now.
As I will work on this project everyday, I will post updates and more questions.
Thanks in advance in Your participation.
Seems all for now.
