goldmember165
- Jun 15, 2020
- 15
Hi All, just joined the forum, I read the adults only sticky and hope I provide the proper information and keep my questions simple to get the fastest help possible. I'm not new to the boating world but am new to stern drives and inboard engines.
Sorry to cram a lot into this post hopefully someone can make sense of it but my current issues are as follows: water in the oil, cracked oil pan, lack of proper shift engagement, boat struggles to get on plane (but after reading forums sounds like gunk in the fuel filters/carb which I will check)
A little back story on the boat since I picked it up: (will post as many pictures as possible)
It is a 1973 Glasply 191VIP (19.5') with the mercruiser 165 inline 6 with MC-1 outdrive...it was given to me for free from a friend because he knew it needed a lot of work (stringers/floor/seats/engine/windshield, the list goes on...) Right off the bat I had to pull the heat exchanger? (what the carb mounts to) off the engine and weld up the big crack in the water jacket that I hear is very common on these engines, l also replaced that gasket (which went well and no longer leaks water from the engine into the boat, woohoo!) I got it running by replacing the coil, plug wires, cap, rotor, points and condensor. (setting dwell and timing) Although it runs and seems to run strong, it has a very odd sound which will make sense in a minute... (if someone has a way I can send a video of it running I can show you), but I took it out on its maiden voyage anyways to make sure my bellows/transom work didn't have any leaks. I did driveway tests with muffs on and didn't have any issues there. What i found after running the engine up to normal temp under load was oil dripping from the bottom, put my hand underneath and turns out there is a crack in the oil pan
I'm hoping someone previously tried to jack or hoist the motor from the bottom and dented the oil pan upwards, causing the crankshaft to hit and then eventually crack the pan. I haven't got to taking it off yet because now I have to cut my newly built floor up and remove fuel tank and hoist up the engine a little in order to be able to slide the oil pan out. I'm really hoping it has been dented in by some i*d*ot and not a crankshaft issue or something internal. Has anyone had a similar issue or heard of this kind of thing before? (I have a hard time believing its crankshaft issue since it does run good
and reaches high rpms and holds it no problem)
Also, when running on the lake yesterday the boat was struggling to get on plane, like I mentioned up top (and understand it could be dirty fuel system/carb), but once it finally gets up to speed the rpm gauge was showing 6000 and didnt have gps to see how fast I was going but definitely didn't feel like 40mph. It has a mint condition quick silver LaserII prop I believe is either 21 or 23 pitch...whether that would cause that much difference or not in RPM's, I doubt it. Anyway, the prop also has a very slight, but noticeable by eye, wobble to it that appears to be the shaft that its mounted to. The gear oil that came out was disgusting and there wasn't a whole lot in there, I replaced it and filled to the proper level where it comes out the vent screw hole. Also replaced gimbal bearing and bellows.
Sorry for the long story and I know I have some work to do and can probably answer my own questions by just getting out there and getting my hands dirty but was looking for some insight and knowledge from the experienced.
To summarize my issues; cracked oil pan, water in oil, slightly wobbly prop, sluggish engine out of the hole, high rpms, poor shifting.
Thanks for any info!!!
