Progressive pitch props
89retta
Trying to find out what company makes and sells these. Are Solas or Turning point props progressive pitch props? Thanks for any info
Sea Rider
Progressive pitch props are costly. If wanting going for a cheap alternative Defender is selling all their Propulse props at bargain prices, check with them if having one for your current set-up.
Happy Boating
89retta
I think your taking about variable pitch props which are costly. What I'm looking for are progressive pitch props. The one where they would start at a 17" on the leading edge and end at a 19" on the trailing edge
Texasmark
Most SS props are progressive. Pitch changes as you go across the blade but is sold on the average pitch effect. You may be asking about rake which is the bending of the blades back from where they emanate from the blade root. Most SS props have rake in the higher pitches.....19 and up. Rake helps to lift the bow of the boat out of the water, reducing the hull wetted area and thus increasing the speed and rpms for a given throttle setting and the right trim angle.
