Re: Products/techniques for frozen head bolts
Yes. Yes. You should be. Yes. Yes.<br />To elaborate, the bolts may be frozen in the threads, they may be frozen on the shaft in the head, or both. I had a similar problem with my outboard. Using heat and PBBlaster I still snapped the head off of a headbolt. Even with all the other head bolts out and the head off of the broken one I had to beat the #%&# head off with a rubber mallet. The shaft of the bolt had corroded in the bolt hole in the head. It is amazing the grip that salt water corrosion can have on the smooth shaft of a bolt. Once I got the head off I was able to unscrew the remnant of the bolt with my fingers. If you are going to work on a salt water outboard you need to get familiar with a tap and helicoil, and methods for extracting frozen bolts, because they are commonplace. Penetrating oils like PBBlaster are useful but very often as in the case I described the corrosion is too far in from the surface to be reached by any penetrant.<br /><br />Use heat first not as a last resort. Do NOT use EZ-outs as the grip of corrosion exceeds their breaking torque and you will need to learn to extract the extractor. Use the penetrating oils. Use a impact wrench. Use patience. Use a drill, grind the stub flat and center punch and start with small drills and work up to bigger ones. Use a Dremel or similar high speed rotary with a carbide bit (like a tile grout bit) for keeping holes centered if they drift offcenter.
