Paul_Dublin
- May 30, 2004
- 32
One of my YAM 60's was down oc compression on bottom (of 3) cylinders.<br />Stripped down and discovered ring must have broken and smashed around so I ordered 3 oversize pistons, gaskets etc and got engine machine shop to rebore block. This is the first time I've rebuilt a motor. (just like building a big fire, I feel very manly!!).<br />Happliy it started OK, but I'm not sure if I have to "run in" the pistons and rings at low revs before I put it under any power??<br />I ran it for about 5 mins at tickover and then removed sparks and noticed some (Very fine) metal filings. As I completely cleaned the parts and deburred the ports I hope they are just the rings getting the sharp edges off? <br />As a precaution, I poured a few spoonfulls of 2 stroke thorough the spart holes and restarted the next day. Sounds good, but I'm not sure if I need to do anything else before I run it in anger?<br />Anyone done a rebore with any suggestions?
