problems with trim /tilt pump
pioneer
my trim motor started playing up last time we went out. <br /><br />an intermitant problem going up which sounds like the pump slowly stops . i think it may be the soleniod at the bottom which controls the up/down trim/tilt, which has jammed and when i try to lift the motor it is pumping against itself.<br /><br />has anyone else had this problem? is it possible to service the solenoid valve thing.
johnkc
Re: problems with trim /tilt pump
pioneer ,what motor you got
johnkc
if it is an intermittant prob. it probably is the down sol. getting energized somehow<br />solenoids are replacable ,but make sure the wiring on the boat and engine are sound :cool: the solenoids change the direction of the motor rotation ,they don't actually valve the hydraulics
