tri-hull merc165
- Jun 5, 2005
- 5
I have a 1970's mercruiser I/O straight 6 165 engine. the boat is turning over but not starting at first i thought it was the fuel pump since no gas was getting past the pump now the gas is getting to the carb since i replaced the pump but i dont see gas going down into the carb at all. i have checked the fuel filter inside the carb and cleaned it out and reinstalled it and still nothing. Also how do you check to see if your coil is still in good shape? let me know any other info you need to know and any help or tips would be greatly appriciated. oh and also my card is a GM 2 jet carb. The boat started and ran fine about 2 months ago then it sat for the 2 months and this happened when i tried to start it up before going out to the lake.
