I just bought a 1981 thunderbird formula with a 140 hp mercury engine. I had problems when I took it out for the first time. It did not want to start without starting fluid since that is what the old owner was using to crank it over. Also when I was out on the lake it stopped while trolling and after I got it started and ran it at full throttle for 15 minutes it would not respond to the throttle and after a while it stopped and did not want to start back up even with the starting fluid. <br /><br />So my questions are can I get the engine to a point where it does not need starting fluid to start, where can I find the serial number for the engine? and would changing spark plugs help it crank over again. Thanks for the help in advance.
