Pokertrampp
- Sep 17, 2009
- 279
I have a 1988 Johnson 120hp (J120TLCC), it has been giving me trouble for some time. it has a signifigant mis and it seems to come and go and go from one cylinder to another. This is what has been so far:
1) Rebuilt Carbs 3 Times
2) Replaced Coils
3) Checked Stator and Timer Base (both check out ok)
4) Changed Spark plugs and plug wires
5) Checked Compression (100+ on all cylinders)
6) The motor is NOT charging the battery, I have orderd a new rectifier, should be here any day. when The battery is low I can turn the motor but do not get any spark on any cylinder, if I charge the battery I get spark on all cylinders, is this normal? I thought you were supposed to be able to pull start it with a rope even if the battery is dead. could this be the cause of the mis, the mis is there even if the batter is fully charged.
2) Replaced Coils
