pkrainert
Thread starter- Joined
- Jul 27, 2008
- 196
I have a 7.5 Ted Williams outboard that runs for about 5-10 seconds then dies. It ran for 3-4 days just fine. Aside from running rich. I have noticed that fuel leaks out of the carb bowl from the spring loaded screw. When i try to start the motor i have to advance the throttle all the way and make sure not to pump the fuel line. and like i said it runs for about 5 seconds or so. If i start it without the propeller engauged it will run a little long about 10-15 seconds. The only things i can think of would be too much fuel or the spark plug is on its way out. any ideas how to fix the carb? is it the float or jets?im not to experianced with carbs and i dont want to screw it up.
