Re: Problem with power trim
When I worked on mt T&T, I could not find an after market source for the relay. Had no problem finding the motor. If you have a good source, share it with us.
Correct p/n can be found at yamahaoutboardparts.com ( RODBOLT hangs out there). If you get the correct p/n you should be able to cross reference it to other vendors. I did that with the motor at sierraonlineoutboardpartscatalog , motor cost a fraction of what YAMAHA wanted.
If you find you do need a motor, unlikely, let me know. Its yours, 2 wire-4 bolt flange. YAMAHA p/n 64E-43880-01-00. regards FRED
