Re: Problem with fueling up boat
a little more info could be helpful,
when the filler neck is full does the fuel sit there or does it slowly go down,
if the fuel is sitting there does the tank burp(bubbles of vapor come through the fuel) while gas goes down,
or does the backflow preventer kick the pump off.
How long have you had this boat?
Your going to have to check your filler line and see if it is kinked..
Make sure you vent and vent line are clear and not kinked..
If that isn't the problem there may be something in the filler neck or line blocking it which would probably require removal of the line.
my boat is picky about how far you put the nozzle in and will trip the backflow preventer shutting down the pump
